Yooshaw
- Feb 10, 2014
- Texas
- 2x Mobius, 2 x SG9665GC, 2 x A119S, 2 x A119V3
Decided I need to make a thread on this rather than posting in similar threads.
My intent is to get these (I have two) back in action (have been sitting on the shelf over a year since my move to Florida). I initially got these capacitors to try and replace my battery in my Innovv C2.
https://www.aliexpress.com/item/2Pc...32571210201.html?spm=2114.13010608.0.0.fueBnJ
At first tried just one of these, and that failed. Then wired two in parallel, and that worked the first time I tried and it saved the last file - but then it never saved the last file again. On top of that, the two button cells are still too large to fit in the case and close. While I know I can mount the capacitors outside the case, I'm going for a clean install.
I happen to have a dead DDPai Mini 2, so I harvested its capacitors. They look to be the NForce (green), rated at 2.7V 5F (two total). I wired them in series and my Innovv C2 seems to work! So that's great, but these capacitors are way to big and would have to be mounted outside. Also, as @Dashmellow has pointed out in other threads (as have others), cell balancing is a concern (I read through your GT680W thread, great read and info).
I measured the voltages - 4.12V across both capacitors, 2.02V across one, and 2.10V across the other. The difference between the two capacitors has me concerned.
So, I started looking for a new capacitor, and ran across this one on Mouser:
http://www.mouser.com/ProductDetail...EpiMZZMuDCPMZUZ%2bYlxdFextp0taVSY%2b6ovCDBq4=
It's dimensions look perfect to fit in the space I have for the C2, and the 15F should be plenty. One of the features listed is "No cell balancing necessary."
4.2V is right on the edge of the max voltage though. There is a 5.6V version, but it's length is too long too fit. Thoughts on running a 4.2V capacitor? Is that too close to the operating voltage? The datasheet indicates that it can tolerate 4.8V for up to 30 sec. Anyone know if Vishay make quality capacitors (I would hope so for over $11 for one)?
