HopWorks
Hi All,
I have been following BC Hobbyist YouTube videos to try to learn how to refocus my front A129 Duo camera. The only snag I have run into is the glue they applied to the focus lock collar. It's much more than I expected, and instead of a clearer softer glue, it's that super hard black stuff that looks like what they cover microcontrollers with in small electronic devices. I removed the camera module completely and considered removing the two screws on the back of the module to remove the lens assembly so I can get it into a vise to make trying to remove the glue easier. But before I do that, I wanted to ask...
Is there a place where you can buy just the lens assembly, including the base that attaches over the sensor (with two screws)?
And if there is and I can change it, should I take advantage of upgrading to a F1.8 lens assembly? I saw a comparison video but not anything about the actual replacement that would tell me if the base that mounts on the camera module is the same dimensions.
Or, is there some sort of solvent I can use to make removing that glue easier?
The glue in this shot actually looks a little translucent but it is still hard as a rock.
I figured if someone would know the answers to any of this, it would be here.
I noticed my front camera was quite a bit out of focus when I tried to watch video recently, and at first I thought it was dash reflections that was messing up the focus, because those items are in focus. But after reading here about the focus being fixed in place with glue, I figured it was just the heat over time that whacked it. I live on the lower deserts in Arizona and we had a VERY hot summer this year. I am actually surprised my A129 and the card inside still works.
Thanks for any help and advice I can get! I appreciate it!
