EricSan
- Dec 28, 2023
- Central PA
I recently received a very kind invitation from Wendy at Vantrue to review their brand new Nexus 4 Pro S Dashcam. A very sincere "Thank you!" to Wendy, @Jeff_Vantrue, and the Vantrue team for entrusting me with another of their cameras for review. I was wondering how different this camera would be from the earlier N4S that I just received, but a quick look at this camera creates some unexpected excitement - this is clearly a VERY different camera. The N4 Pro S is 15mm wider (133mm overall width) and more than 25% heavier than the N4S, plus a few more fun surprises that are described below.
My other Vantrue dashcam reviews can be found here: E360, E1 Pro, N4S, S1 Pro Max, N4 Pro S, N5S
Vantrue Power (non-dashcam) Product Reviews: T800 Compressed Air Duster, TS2 Thermal Camera for iOS/Android
Features:
Voice Commands:
- Take Photo
- Video Start
- Turn On Audio
- Turn Off Audio
- Turn On Screen
- Turn Off Screen
- Turn On WiFi
- Turn Off WiFi
- Lock The Video
- Show Front Camera
- Show Rear Camera
- Inside Video On
- Back to Homepage
I have verified that all of the voice commands work as expected.
Maximum Resolutions Are as Follows:
- Front camera: Starvis2 IMX678, 3840x2160P 30fps, 31.9Mb/s, 236,202Kb/Min file size (data rates and file sizes are in Post #33)
- Cabin Camera: Starvis2 IMX662 (with Automatic IR LEDs), 1920x1080P 30fps, 0.98Mb/s, 74,410Kb/Min file size
- Rear Camera: Starvis2 IMX678 (waterproof), 2592x1440PP 30fps, 14.3Mb/s, 107,178Kb/Min file size
All files are encoded with H.256 video codec which is claimed to produce videos with file sizes that are up to 50% smaller than those made with the H.264 codec.
When compared with the N4S, the N4 Pro S front camera is higher resolution (4k vs 2.5k), the cabin camera is lower resolution (1k vs 2.5k), and the rear camera features the same resolution (both 2.5k). There are a few surprises hiding inside the larger N4 Pro S (which appears to be the big brother of the N4S).
Taking all of the size, weight, codec, and bitrate data into account, it's looking like the N4 Pro S features the highest image quality of all of the Vantrue cameras that I've reviewed so far. It has the same front camera resolution and data rate as the excellent E1 Pro but features the more efficient H.265 codec (the E1 Pro uses H.264) and features 30% larger file sizes than the 4K S1 Pro Max. This likely makes the N4 Pro S Vantrue's flagship dash camera. Needless to say, I'm excited already and I haven't gotten very far yet...
Camera angles:
- 155 degree angle front camera
- 160 degree cabin camera
- 160 degree rear camera
Power Consumption Measurements:
Power consumption data is contained in a nice table in post #68
User Manual and Firmware Updates:
www.vantrue.com
There is support for 32GB-1TB micro SD cards as well as for the LTE module (each available separately).
Like other Vantrue dashcams, the Nexus N4 Pro S uses super capacitors that provide 3-4 seconds of runtime after power is removed from the camera.
As with the E360 Ace, E1 Pro, and N4S, and S1 Pro Max cameras that I reviewed previously, the packaging materials are excellent.
The usual foam inserts hold everything snugly inside the box:
And here is everything that is included in the box. There is now a small alcohol pad included for cleaning the inside of your window before applying the static cling sheets for mounting the camera to your window. The usual 3.3ft/1m long data cable with a USB-A connector on one end and a USB-C connector on the other end is included for transferring files to your computer. The USB-C cable for the rear camera is 20ft long, has a straight USB-C male connector on one end, and a 90 degree USB-C male connector on the opposite end.
Features:
- Triple STARVIS 2 Sensors (Front: IMX678, Cabin: IMX662 + 4 IR LEDs, Rear: waterproof IMX675)
- 3-Channels: 4K+1080P+2.5K Recording
- PlatePix™ License Plate Capture
- Optional LTE Live Monitoring
- 5GHz Wi-Fi & OTA Updates
- Built-in GPS Tracking
- Up to 1TB microSD Support
- 24/7 Parking Mode
- Easy to Install & Super Capacitor
Voice Commands:
- Take Photo
- Video Start
- Turn On Audio
- Turn Off Audio
- Turn On Screen
- Turn Off Screen
- Turn On WiFi
- Turn Off WiFi
- Lock The Video
- Show Front Camera
- Show Rear Camera
- Inside Video On
- Back to Homepage
Camera angles:
Vantrue N4 Pro S | Product Manuals, Firmware Upgrades, and FAQs
Explore comprehensive product manuals, firmware upgrades, and frequently asked questions (FAQs) for Vantrue N4 Pro S dash cam. Access detailed instructions, troubleshooting tips, and the latest firmware updates to enhance your experience. Find answers to common queries and optimize your use of...
www.vantrue.com
