Sunny
- May 31, 2014
- Colorado
- United States
- More than I can review. ;)
Rexing sent this camera for review. Thank you Eric.
Summary from my later post after tests:
The V1 is based on NT96650 chip and it's available at Amazon:
https://www.amazon.com/gp/B00X528FNE
This is my first camera that's little different design than the normal camera style.
This is slanted/angled and comes with a very thin mount that allows it to be mounted flat against the windshield.
Physically, it's 2.5" wide and 3.5" deep. Thickness is around 1.5".
The camera comes with the following:
Here is Rexing V1 side-by-side with G90 and Rexing F9 (similar to G1WH in size/shape):
Right side has mini USB, GPS and optional rear-cam ports (my unit didn't come with GPS nor with rear cam so can't comment on those):
Left side has Menu, Reset and Power buttons along with microSD card slot:
Both left and right sides have a knob to adjust the camera angle.
Top side has hole for the mounting bracket and vent holes. Vent holes are all around.
The back has Mode, Record start/stop, Microphone, Event/OK button along with something that I haven't seen before, a button to turn the display off/on. That's in addition to the backlight settings. Nice!
Mounted alongside G95A:
From outside, bad reflection but good for hiding the camera:
Compared to the long hanging mount of G95A, this V1 is up against the windshield and much more discreet.
From inside the car: Compared to the long hanging mount of G95A, this V1 is up against the windshield and much more discreet.
It is great as it can be mounted up high under the windshield Sun shade and since there is no suction cup mount and the provided mount is very thin, it's more discreet.
More to follow with sample videos...
Overall, it's very good compared to other NT96650 based dashcams.
It's better than generic G1W ones and on par with the better models.
Daytime videos are great with all areas in focus, no soft/fuzzy areas and night quality is good enough.
Audio is excellent though, clear, loud and no distortion.
Most of all, it's design is to go for as it can be mounted flat against the windshield up high and being all black, it's much more discrete than those hanging from suction mounts as well as easy to slide and take it out.
- Dash Camera
- Flat mount
- Double sided 3M adhesive tape for the mount
- Car mini USB Charger
- mini USB to USB cable
- Manual
