HonestReview
- Feb 9, 2019
- Sweden
I have an Sandisk A2 Extreme 256GB in my A129 Duo that has never had issue. I also had a Sandisk High Endurance 256GB in the Zenfox I used and it failed (Developed Bad Sectors) after a very short time in use..I was mailed out a replacement Sandisk High Endurance.
I go out to my car today and I get a Storage Error No Sd Card Found on My A139. I popped in the extra Samsung Pro Select 128GB and it worked fine. I put the Sandisk High Endurance in a media reader and it reads fine.
Only change I made was Viofo asked if I could disable loop recording to see if on overheat, the last files (front , rear, interior) are corrupted.
I'm going to do a low level format on this Sandisk High Endurance 256, but wondering if this 2nd card is failing......
