SC400D and newer cars
KennyG
NY
I have a SC400D in a 2025 Maxda CX-5 with the "new" hardware kit hard-wired, and have been working with Cobra for a full year with no solution. With autoshutoff set to 1 hour the camera turns off, while driving, after driving for 1 hour. And Cobra support says when autoshutoff turns off the camera it has to be manually turned on - starting the car will not turn on the camera. Note, starting the car also does not turn on the camera if it is manually turned off.
All the various testing indicated that the camera does not recognize a signal on the the red ACC wire. Yes, all wiring is correct.
I recently asked if they have a certified installer and was told - no, but try Best Buy.
Best Buy said the "new" 3-wire hardware kit does not work with newer cars and suggested a kit that provides constant power to the camera, which probably defeats shutoff functionality.
I also did a search and found "apparently some newer cars are built to work on lower power levels and have a certain degree of varying/fluctuating voltage/current which causes this safety device to trip".
Has anyone experienced this, and what is the solution?
