Secondary Camera
estore009
Retailer
Shenzhen
China
B1W/B2W/B2K/B4K/DV688/DV988/B1M/B2M
Sir, can you share the sensor, lens, and angle of view specification for this rear camera? Thank you!
Check details on website!
richx
Malaysia
GoSafe S50, Mijia 1S, A129 Duo, A139, Mola N3, Mini 5
I find:
Key specifications:
Video resolution: 1080p
Lens angle: 130 degree
Camera size: 60*28mm
Camera Footprint size: 26*22mm
Camera cable length: 6 meters
I can only find mention of the front sensor, no obvious mentions for rear sensor (box and tube types)? Did I miss it somewhere? :censored:
richx
Malaysia
Ordered one, can't wait for it to come to check out the buffered parking mode (y)
neomax71
France
DR650GW/S 2CH-DOD RC500S -AW1-Blueskysea B2W-VIOFO A129 Plus
Or buy the rear camera for the on aliexpress or amazon B4K
ketchuphed
ketchuphed
Amazon.com is showing back in stock June 15. Is there another source to get this quicker?
deoccultist
Au
Just ordered one from ebay...
After I install the rear camera does it mean it will use up double the storage space recording front and back?
I might need to get a new micro SD... I only have 32GB.
SawMaster
SC
Numerous and ever-changing
It's all about having the recording time you want. A 32GB card is considered small these days since bitrates are higher to allow for high-resolution cams. It should cover the average commute to work and home, but with a 2-channel cam I prefer 64GB and up. Cards are relatively cheap and you can get good 129GB cards for $35- $40 so that's what I'd recommend having. Keep the 32GB card handy for FW updating and as a spare.
kamkar
Denmark
10 years, many dashcams
32Gb are very little, you should at the least have 64GB for each camera in a setup, so 128 GB in your case.
richx
Malaysia
It's sad. I've waited so long, and then they declared it as lost. The refund has since been credited back into my payment card, but I'm a bit weary about ordering again ... Maybe on Monday I'll feel a bit more optimistic about the logistics system ...
Denis53
NSW
Blueskysea DV988 Street Rod, B4K Ute
Hi, have just installed the B4K with rear camera, my question is how do i adjust the rear camera view, objects are at 45 degrees on viewer.
Many thanks
Denis
estore009
Retailer
Shenzhen
China
Denis53
NSW
tried that, still upside down,Screenshot from 20210420195142_000012B.TS.resized.png
R B4K 0
Similar threads
Front camera is amazing!
