richx
- Nov 30, 2018
- Malaysia
- A129 Duo, A139, Mola N3, A119v2, B4K
Sir, can you share the sensor, lens, and angle of view specification for this rear camera? Thank you!
Check details on website!Sir, can you share the sensor, lens, and angle of view specification for this rear camera? Thank you!
It is on the way to the AMZ warehouse, will update when it arrives!Amazon.com is showing back in stock June 15. Is there another source to get this quicker?
Just plug to play!After I install the rear camera does it mean it will use up double the storage space recording front and back?
It's all about having the recording time you want. A 32GB card is considered small these days since bitrates are higher to allow for high-resolution cams. It should cover the average commute to work and home, but with a 2-channel cam I prefer 64GB and up. Cards are relatively cheap and you can get good 129GB cards for $35- $40 so that's what I'd recommend having. Keep the 32GB card handy for FW updating and as a spare.Just ordered one from ebay...
I might need to get a new micro SD... I only have 32GB.
Thanks for the tips guys!32Gb are very little, you should at the least have 64GB for each camera in a setup, so 128 GB in your case.
Its rear camera is available on Amazon nowAmazon.com is showing back in stock June 15. Is there another source to get this quicker?
my question is how do i adjust the rear camera view,
