Setting the bitrate 1080p to 60-90mbps ?
blacki2015
Bahamas
Request info or can be set in the autoexec bitrate 1080p 60fps in height from 60 to 90Mbps ??
you have a sd card that can handle those rates?
If you do have you put a heat sink as big as the Yi on the Yi so it does not overheat and turn to goop?
I have a card microSD 16GB U3 C10, and my recordings have max 55Mbps ...
you wont see any benefit. there is not so much information on sensor data.
or do you see macroblocking now?
No, just create another thread..
