jonpickles
OK still want it to go off but only if things get really close
This is where it gets interesting.
From reading other posts it seems you do this
Put SD card in computer
Open Blackvue folder
Click on Config to open folder then on 2nd line it should open in Notepad.
Click on EDIT on Taskbar
Go down to motion sensor and change value to 1 Mine was 40
Save and exit
Apparently that should fix it as well as you an
Can you explain this further, are you saying that in 'Park mode' moving objects in the view of the camera will make the camera start recording?Lol what setting for the parking so that nothing visually sets it off please
do you think its the card? its a 32gb sdhc https://www.ebay.co.uk/itm/291063494785 i also own this https://www.ebay.co.uk/itm/291061277535 do you think i should use that? or maybe the pittasoft 16gb that came with it?
Not necessarily Just do the test on them all and then you will knowI want to get close contact but not passing cars etc all I want to record is what you say someone damaging my car or hitting it just don't want casual passing of cars and will try that link you gave me to test card but do you think the pitasoft is sufficient anyway?
Doesn't look too flash either I would run it again after it has fixed the errors and see what it sayspitasoft 16gb
Error writing file 'E:\4.h2w', offset 0x1d400000.
It is still possible to verify the test data written up to this point.
(The system cannot find the file specified. Code 2)
Warning: Only 15262 of 15263 MByte tested.
Writing speed: 13.0 MByte/s
H2testw v1.4
then it asks if i wanna scan and fix errors or continue without
G | DR500GW Recording to dark | DR500GW-HD | 7 | |
S | Custom Firmware 1.1.1aE - TimeZone settings for Queensland, Australia | DR500GW-HD | 17 | |
DR500GW-HD Parking Mode Settings | DR500GW-HD | 1 | ||
T | DR500GW-HD Anyone know how to reset the camera to factory settings? | DR500GW-HD | 1 | |
S | Changing settings | DR500GW-HD | 4 |
