It says, SG 20180726_V1.32 If it's working, that's all that matters, right?
you should definitely update, there are a lot of changes and bugfixes since then, update here
http://bit.ly/SG9663DCfirmwareV1-49 instructions are included with the download
list of changes since your version as below
Street Guardian SG9663DC (SG9663DC.bin)
Firmware bin file MD5 values can be verified using WinMD5Free, download from
http://www.winmd5.com/
Date:2019-10-22
Ver: SG20191022_V1.49 (Release update 6)
SG9663DC.bin MD5 checksum cff551a36d9ef3d123058497114b9b23
01. Bugfix - Auto restart process after manual restart
02. Bugfix - Manual power on process
03. Delete - Short press MENU button while recording to take a photo
04. Delete - WiFi menu setting (short press power button while screen is on to enable/disable WiFi)
05. Add - Long press the MENU button while screen is on to pause recording and enter menu
06. Add - Configuration changes to suit mobile Street Guardian APP
07. Change - Modify the boot delay process
08. Change - Modify the WiFi function while in standby (beep while no active connection)
09. Change - Modifications to suit iOS and Android apps
10. Change - Adjustments to Parking Monitor to suit APP
11. Change - WiFi improvement
12. Change - Adjustments to WiFi
13. Adjust - Change the power on and power on delay logic
14. Adjust - Menu display icons
Date:2019-03-15
Ver: SG20190315_V1.39 (Release update 5)
SG9663DC.bin MD5 checksum 109bdefc2fd7661578fb3e2d14ed0aa4
01. Adjust - Update display icon for low bitrate 30fps parking mode option
02. Adjust - Update parking mode G-Sensor values
03. Add - Low bitrate 30fps parking mode option
04. Add - Parking mode G-Sensor option
06. Adjust - Timezone settings
07. Adjust - SSID default value
08. Adjust - Russian menu translation corrections
09. Adjust - Default system date
Date:2018-10-26
Ver: SG20181026_V1.35 (Release update 4)
SG9663DC.bin MD5 checksum b418ba24c71a9d3a02ab1baf8ad82336
01. Bugfix - Emegency icon not clearing in parking monitoring mode
02. Bugfix - Recycle function in timelapse mode
03. Adjust - WiFi mode - "Press Select to Disconnect" corrected to "Press Power to Disconnect"
04. Adjust - Russian menu - AutoRestart menu error corrections
05. Adjust - The GPS signal icon has been updated RED icon = No Signal, GREEN icon = Signal
06. Adjust - MIC icon has been updated RED icon = MIC off, GREEN icon = MIC on
07. Adjust - Add audible alerts to more card fault categories
08. Adjust - Relocate GPS icon to top toolbar for better visibility
09. Add - Additional fields added to service mode setup process
Date:2018-09-01
Ver: SG20180901_V1.33 (Release update 3)
01. Bugfix - Mode change problem during parking mode
02. Bugfix - Improve cold start process
03. Add - Additional options to countdown timer menu
04. Change - Add input power menu option for 2 Wire (default) for cig power, or 3 Wire power for SGDCHW
05. Change - Adjust logic when changing from normal mode to parking mode for 3 Wire power input
06. Change - Data connection properties
07. Change - File structure for Street Guardian Dashcam Viewer playback software
Street Guardian Dashcam Viewer for Windows
http://bit.ly/SGviewerWIN64
Street Guardian Dashcam Viewer for Mac
http://bit.ly/SGviewerMAC
Street Guardian Dashcam Viewer user manual
http://bit.ly/SGviewerManual
