Activating WiFi is no longer done in the settings menu. It’s easier now on the latest firmware.
With the camera on and recording, short press the power button while the LCD display is on.
The camera will display that WiFi is now activated, and will begin to beep – this is normal behaviour. The camera beeps anytime it's not recording or you're accessing the menus, it does this intentionally to let you know it's not recording
The camera will display a WiFi SSID (Network Name) and the default password, which is 12345678. The SSID will look something like this SG9663DC fgceee8ea71wb2356ab56 and is different on every camera.
Open your WiFi settings on your mobile device, and find the SSID in the list of available WiFi networks. In our example, you would look for and connect to SG9663DC fgceee8ea71wb2356ab56.
Select the SSID and connect, when prompted enter the default password 12345678
Once connected, you may see a message advising that no internet is available on this network, if so, accept or agree to this, as the camera does not provide internet access. We are only creating a Peer to Peer WiFi connection.
Once you confirm that the WiFi connection has been established, you can then launch the Mobile App and you should then have access to your camera and its settings from the App.
