SG9663DC + parking mode settings
razvanciobanasu
Romania
Hello. Can somebody show the corect settings for all params for those cams with parking mode installation? Maybe a step by step settings or a video tutorial. Thanks!
When you have the hardwire kit just set the power input menu to 3 wire, default settings are 1fps time-lapse and 10 minute shutdown, you can adjust either of those as you like, there's not much else to know, it's pretty straightforward
Ok. I understand. 1 fps , 10 min are ok? What about bootloop set and others that now I dont remember it? Cause I think I do not understand all params.
there's no other settings needed for parking mode, just the power input setting to make it work, the other settings are just options to choose, what frame rate you want, how long you want it to run, oh and the G-Sensor has a separate adjustment when parked also, that's it though
Ok. Thanks. I saw that it capture few clips in parking mode and I consider that my cams are off during parking and thats why I ask about setting.
It stops, I think. No intermitent red light on rec button. When I turn on the car, the cams sound like turning on.
Check if the parking mode hardwiring kit wires are correctly connected.
Ask the installer to double-check the ACC (switched) and BAT (constant power) connections and test them with multimeter.
Sent from my VKY-L29 using Tapatalk
Your specialist has not connected it correctly, sounds like the yellow wire is on an accessory switched circuit instead of a permanent circuit
Your specialist are probably not a specialist after all, chances are :
1: He connected both + wires to the same ACC outlet.
2: He He did not connect the always on wire at all.
3: He did not use the hardwire kit but just used the regular mans of power, just cut off the 12 V plug to wire it into fuse box.
That is all the reasons i can think off, that will let your dashcam power on and off like a regular camera without parking mode.
I talked with the specialist and told me that he is sure that connections are ok, but the parking mode is not working. I have to check
I assume hard wire kit could be broken too, but i don't think it is the camera itself.
I just checked for myself. On yellow wire I have permanent +, on red is + through contact switch, and black to metal. The red light from hardwire kit is on.
Could it be the parking sensor from cam that it can be broken and ot doesnt put the camera on when in parking time?
I just checked another thing. I leave camera in wifi mode and locked the car. I see the camera live for a few seconds then I lost it.
Check page 8 of the hardwiring kit user manual.
