what firmware version are you on?
I am on beta FW v1.34T which was the "latest" at the time of installing the dashcam.
you could easily test by just taking the CPL off the front and putting it on the rear for a while and see how it looks
Good shout I will have a play and compare results, are the CPL filters the same or just compatible front and back? If I find it is beneficial I will give Niko a shout and order one
ok I thought that might be the case, you need to install the release version V1.33, it will stop those odd switching situations you have http://bit.ly/SG9663DCfirmwareV1-33
you can't keep some settings on upgrade but we will have a function where you can very easily reload your settings, we're working on that now along with a couple of other things
How does the new one differ from the old? And what is the real world impact?give it a try but if you like it hang off before you order one as the updated one is due soon which will be better for the front and you can use the existing one on the rear
Just an FYI - I removed the CPL from the front camera this morning and the shadow artifacts are still present so it's nothing caused by the filter. The 'DC' had the same so I may do some testing with a 'GC' and A118-C to try to confirm that, as I expect it may be, something to do with the windshield glass and/or mounting location.I will have a look at the video in about 12 hours, at the airport at the moment, phone isn't the best for checking this sort of thing
Just did some recording with both a Spytec A118-C and an SG 'GC' v2 and the same artifacts show so it's something to do with the glass and/or mounting location. It is what it is so I'm (hopefully) done playing with it...I may do some testing with a 'GC' and A118-C to try to confirm that, as I expect it may be, something to do with the windshield glass and/or mounting location.
why you using 1.33? that is soo old and full of bugs. upgrade to 1.37 or did someone tell you to try 1.33??
1.37 has been released, you can download from the support page of our siteJust realised I quoted the wrong comment original this is where I was asked to install 1.33, I'll update now hopefully this will resolve the issue
