SG9663DCPRO menu glitching, reboots or turn off completely
ezuser
One of my SG9663DCPRO is having issues within the menu screen. While in the menu selection screen, moving up and down to change settings, the unit would just sometimes shut off completely and not turn on or shut off and reboot. Sometimes just pressing REC to stop recording sends it into a reboot.
I've switched the unit to my other car, switched the card in it, reformatted it, it's up to the 1.17 FW, I've included also removing rear camera, also tested it outside of the car at home with a 12v adapter to the cigarette plug. Any other troubleshooting I should try? Have others run into this similar issue?
Street Guardian USA
Retailer
Oakland Park, Florida (USA)
StreetGuardian.CAM Amazon.com
That behavior sounds like a rear camera communication issue. Test with the rear camera unplugged. If that works, test with the unused secondary rear camera cable loosely ran.
Next most common thing with that behavior is a bad memory card. You'll need to test with another card to rule that out.
E
ezuser
Same issue with no rear camera plugged in. Also, switched out memory card with another and same issue. What's next for troubleshooting?
E
ezuser
Thanks. I can't seem to create a ticket. I get a spinning icon that never stops. This occurs on several browsers that I tried on. Do you want me to contact via the Contact Us form or through private conversations here on this forum?
Street Guardian USA
Retailer
hmmm not sure what's up with that. It just worked for a few others customers recently. Yes, a private message is fine. Send all the same details the support ticket asks for.
E
ezuser
Thanks, messaged you, will go from there.
