The mount has gotten very loose on mine.....so much that it is coming off while driving.
must be loose to actually come off
- GPS longitude is still showing negative, which causes the Shadow Player software to think the location is somewhere in China, and east/west are reversed on the map display.
Shadow Player shows I was driving on frozen tundra in Tibet, China. Would be wonderful to have the cool air in Florida, even it may contains less oxygen. The negative longitude is correct for US, you can see google map shows the Tibet location with positive longitude. The software engineer dropped the negative sign. And yes, east/west are reversed on the map but compass on player shows correct direction. It should be fixed once the 'minus' sign issue taken care of (direction reversed).
Wow, what the difference a media player can make! I downloaded Registrator Viewer and it not only displayed all info correct, but also rendered video in higher quality. I can see nearby cars' license plates!if this model is supported by Registrator Viewer there's an option to invert the co-ordinates to deal with this error so that things display correctly
Dash cameras with parking mode will usually go into parking mode when it's enabled in the settings. What your describing sounds more like Time Lapse.I've used this dashcam for a couple of weeks now, and tried out Parking Mode recently. Parking Mode can be selected to save an image every one second or every 5 seconds, which it does, whether the car is driving or stationary. But it seems that Parking Mode can only be turned on or off by manual selection, not automatically. Ain't nobody got time for that!
Anyone know if there's an automatic setting that will select Parking Mode when the car is parked?
