dteal
"If you're not willing to take the approaches being recommended to you, then nobody can help you in any way"Nobody checks sharpness of focus on moving objects for very good reasons which have already been explained here. Not Nikon, not Canon, not any of the professional grade video cams. That is always the first step and of all testing also the easiest to do.
The easiest way for most people to do this is to park perpendicular to a large brick wall at a distance of 15m or more with the sun behind you being equal all across the wall. The high contrast between brick and mortar and the very straight lines will make any image distortion or lack of clarity very evident across the entire FOV of the cam.
If you're not willing to take the approaches being recommended to you, then nobody can help you in any way. It's not like it's hard to do but you must try- we can't do it for you.
My opening question was " Anyone else having poor image problems with the A119 V3???"
So I was expecting a wealth of experience of instances of poor image quality, as after that is what I was asking.
I was asking for possible causes, not asking for a testing procedure as I am quite capable of devising my own testing procedures for any cause I was to investigate.
To your credit you offered the 'left field of view issue', one that I actually was aware of. Unfortunately the rest of the replies were all about the car speed being too high and light level too low, both of which I dismissed as I have pulled great images off my A119S at more than double the speed of the cars in this instance, and that the lighting was not low although people have obviously mistaken the lack of washed out highlights (due to exposure at -0.3ev) as evidence of low light while ignoring the blue sky. Ironically none of them actually knew what the car speed was, nor the light level.
So instead of offering other suggested causes of poor image, people instead for some reason wanted to insist I carry out "their prescribed testing procedure" and submit the results to them for perusal, presumably in the hope of proving my dismissal of speed and low light as being wrong and them being correct, or they would take their bat and ball..
