Jet-Lee
- Jun 4, 2016
- SF East Bay
- Xiaomi Yi 2k
I couldn't find a situation similar to mine and I've been searching a while. So I registered here to ask since you all really seem to be on the up-n-up in regard to this awesome little camera.
So I opened up my Z23L Yi 2k (I bought it about a month or so ago) to check out the focus. It turns out that it has 4 glue spots (does not come off easily at all) and looks like it's already been turned. I'll put some photos (dirty iPhone camera) below, looking for your input.
Note position of the clip on the lens cover:
More glue:
Here's a 1080p/60fps video using the autoexec.ash from WaffleFPV shown below
It seems blurry to me, and like the AWB isn't turning off. I'm wondering if I inserted the AWB script correctly (after Sharpness Adjustments).
What is "coring" and what effect does it have?
I look forward to input from you camera guys, cause I'm totally new to this and trying to understand all these settings.
More glue:
Code:
# WaffleFPV V8
#--Recording Adjustments--
# 4GB Clipping
writew 0xC03A8520 0x2004
# Sets Bitrate to 25Mbps
writew 0xC05C1EE2 0x41C8
#--Sharpness Adjustments--
# Set auto-whitebalance
t ia2 -awb off
# Coring
t is2 -shp mode 0
t is2 -shp max_change 5 5
t is2 -shp cor d:\coring.txt
sleep 1
# Noise adjust
t ia2 -adj tidx -1 1024 -1
#--Misc. Adjustments--
# Short Beep once script fully loaded
t pwm 1 enable
sleep 1
t pwm 1 disable
