Should I hardwire my dashcam without fuse tap ?
Is it OK and SAFE to hardwire a dashcam without fuse taps
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 3 100.0%
  • Total voters
    3
KiNG_A7MD
Saudi Arabia
Hello everyone
I have the power magic pro hardwiring kit to hardwire my viofo a119s
But I forgot to buy fuse taps with it, so I tried to get those fuse taps from any local store but I haven't found any store selling them, so now I have to hardwire the dash cam into the fuse box without using fuse taps, just like in this picture
instead of using fuse taps
So, is it OK to hardwire the dashcam like the first picture ?
Is it safe ?
If it is OK and safe, can I connect the wire to either legs of the fuse or the hot side only ?
randy
Lukas lk-7900 Ace (2), Mobius C2
Hello everyone
Is it safe ?
Jokiin is much more knowledgeable then me but I had the PMP and used the add a fuse....they are awesome. However, I’ve seen many people just wrap the wire around the fuse legs and it works fine.
Ralph2
Edmonton AB
BlackVue 650GW in 2011 Highlander
Hello everyone
Is it safe ?
Yes, then no.. then definitely a no.
Yes it is OK to hardwire to the fuse. But! wrapping the wire around a leg of the fuse is not very dependable and may work loose.. and it will expand the slot to the point your fuse could fall out.
No, it is not safe as the original fuse you connect to is sized for a certain wire size.. the wire on your dash cam is MUCH smaller and will overheat and possibly cause a fire long before the fuse blows.
No.. you can not attach to either side of the fuse. If.. you attach to the hot side.. you have absolutely NO protection.. you MUST attach to the cold side to get the benefit of that fuse.
For what it is worth.. I soldered the dash cam leads to the cold side of my fuses.. destroying several fuses in the process and then filed down the excess so the fit was the same. My "kit" included in line fuses so I did use them as well. I did not use fuse taps as they would prevent me from using my fuse box cover due to the increase height.
<edit> And a really bad picture of my fuses
Hillbilly
Sunshine Coast
DR750s x2 DR450 x2
You should look a around for these then and if you solder them like you have i hope you covered the excess wire as leaving it like that is as bad as wrapping them around a leg Reply
estore009
Retailer
Shenzhen
China
B1W/B2W/Mini0906/DV688/B1M/DV988
Suggest that you get one fuse,its cost is cheap on Aliexpress.
