kamkar
- Oct 11, 2013
- Denmark
- 10 years, many dashcams
As you might know i already have side cameras, but they are located in a less than optimal place i think.
So i want to try something new, and what simpler to do than take a mobius ( maxi ) put it on a suction cup mount and stick it where you think it will be better.
So first of all a little background info.
On my little Suzuki car i have a little pice of static glass in front of the front door windows, so anything cam go there as that pice of glass dont move, only problem are its pretty close to my mirrors.
So thats the first location i have tried, but i ran into some problems as the glass taper in towards the top and the suction cup can barely allow for a 90 degree angle to the glass, then i had to mount it with the suction cup over the camera and so the lens sit 10 CM lower on the little window than was my plan.
Still while the mirror are in sight in the test footage if i can get camera all the way up ( easy just dont use suction cup mount ) then i think the location are alright for a side camera.
Next up i will try sort of the same as on the most rear part of my rear doors i also have a little pice of glass that are static, problem there is not only do the glass taper in up high but it also taper towards the back of the car a little.
But i am confident a good install can also be made in that location so i can get a good camera aim, only downside are its at the back of the door, so i will have to install the wire to the camera clear across the door from here its hinged, so of course the wire will have to be inside the door.
