AngryArowana
- Jan 16, 2016
- Australia
Hi guys,I'll get straight to the point.
Updated firmware last nite from ver 1.8 to current 2.3 worked fine this morning,around half the battery in,it stops recording & no buttons will work except the power button itself. The unit can still turn ON/OFF & cycle thru different modes with power button but nothing else works pretty much.
If I try to turn it off and on it would try to record for 1-3 seconds then stop recording & keep on repeating it. Also when its under photo mode it just takes photos automatically.
So far has tried,battery change,connected to pc,turned it ON/OFF about 5 times,format memory card (Sandisk 32GB)
Brought it from gearbest on March 2016 used it less then 2 hours of recording time all up,makes the same gyro/static noise as that other post.
Does this seem like to be a hardware issue or could it have anything to do with the firmware at all ?
Thank you.
Thank you.
