dashactioncam
I like to record video of my motorcycle rides. I have an Eken H9R Action Camera that I currently use. While that is a good bang for buck camera, it still is not that great, and I am looking to use a smartphone in it's place.
Problems with Eken h9R: 1. Can't handle direct heat (it was mounted on top my helmet on 100 degree day, changing the location to a chin helmet mount may help). 2. Battery drains too fast (you get about 1.5 hours on a charge at 1080p). 3. Unable to charge while in use.
I looked at dash cams, but In only ride a few times a year, so having an action cam, or using a cell phone makes more sense for me than a hard wired dash cam. I can use these cams (or cell phone) while I ride bicycle, etc. You can't normally do that with most dash cams.
So I started thinking; why not just get a cheap, low end android phone and use that as an action camera/dash camera?
Enter the ZTE Blade T2 Smartphone. $20/shipped. 16GB storage, and can handle up to 256 GB MicroSD.
I have tested the video recording at home (indoors, 73 degrees F). Based on my initial test, this should get about 8 hours recording time on one charge! It's a little bit low on the quality, at 720 but not bad for a basic cheap action camera.
I may end up going with a different device in the long run, just because the low resolution video recording. BUt I am gonna try this out for a bit and see how she does.
Admittedly, heat will be an issue with any smartphone, and with low end action cameras. I mean 100 degrees farenheit and having it in direct sun will challenge most any smartphone and cheap action camera. So I will use a chin helmet mount, which places the device in the shade a bit (if the sun is behind me).
So that's all I have to say for now; I will report back actual results when I have some. This is just my preliminary.
