No, the dashcam has always given me the correct time and date. The only issue I have with my A119 is what I described in my opening post. After 2.5 years, one morning it did not start when I turned the key to IGN. Well, it did, actually. It flashed an image (the correct image, BTW) for about 1/10 of a second and then shut off. I pressed the Power button several times but nothing happened. So I started my 250-mile trip, periodically pressing the Power button in vain. (BTW, the A119 is hard-wired to turn on whenever the key is at the IGN spot.)
At the 200-mile point I stopped, turned the engine off, and rested for about 1/2 hour. When I started the truck again, the A119 also restarted. Now it seems that the problem went away all by itself.
Problems that go away by themselves - - -
return by themselves!
I always thought that the circuitry causes the capacitors to discharge slowly (via an RC time constant) so that in the event of an accident and power is lost, the entire event would be recorded and saved. I will test that shortly by starting the A119, turning it off while counting "1, 2, 3, etc" and then viewing the file to see exactly how many seconds the camera stays on.
