Hi everyone. I upgraded from my Panorama G (2014) to a SG9663DCPRO+ and I have a few questions. (Some info: I am using a Sandisk HE 256 v30 micro SD that was supplied and have firmware version 1.17. GPS Unit not attached for testing, rear cam connected for test)
1. When the unit is on but not in record mode, the unit goes "beep,beep....beep,beep" in intervals of 2 seconds apart. What is the reason for this? Is there a way to turn it off? There are times when I sit and don't want to record the whole time and it might start to bother me.
2. When the unit is off, I press the power button once, and the record light comes on then turns off and the unit stays off. I understand you have to long press to power on but is there a reson why the rec light comes on when short pressing the power button?
3. Is there a way to turn on a sound when the unit powers down? One thing I liked about my panorama g was that it had a turn off sound so I can know without looking that it got turned off by mistakenly unplugging or another accident. If not, could that be added in the future.
4. Would it be possible to take a look at the volume of the shutter sound when an event is recorded (file saved) When reviewing the videos, the shutter sound is loud compared to the rest of the video. This was a problem with my G as well but I'm assuming that it is because the sound is played through the speaker and right into the microphone.
5. When exiting out of the menu when the unit is not recording, it automatically starts recording. Is there a way to turn this off as well?
