arcticfire
- Jun 28, 2015
- United Kingdom
After a run of bad luck with 0805s and 0826s I'm looking to get a different brand.
They will all be hardwired using the Nextbase hardwire kit so the 12V/24V factor is not an issue but they will be wired to a fuse which is not always on because we need to provide privacy to the employees when they switch off the engine whilst on their breaks. I've also got Mini-Micro USB adapters (Nextbase use Mini USB)
Here's the essential requirements:
Here's the desired requirements:
Any suggestions would be greatly appreciately. I've been browsing through lots myself but I can't tell if part of the suction cup adapter can be removed and replaced with an adhesive pad? It looks like they can but not sure. The size doesn't really matter as it's going into commercial HGVs which are securely parked at night.
The ION has been 100% faultless so far but it's far too difficult to obtain GPS data. If the Mini series were reliable then they would be ideal but alas all of the 9 cameras I bought have failed in some way or another.
- Must be 100% reliable with recording video
- Must create a separate GPS file for viewing in registration viewer
- Wide angle due to the size of the windscreen
- Records audio
- Budget is about £80-120 max per camera
- Can take Class 6 32GB cards
- 1080p
- Micro or Mini USB to supply power
- Ideally be an adhesive mount style and not suction cup (unless the suction cup one could be easily adapted to use adhesive)
- Driver stamp
- Speed stamp
- Can take Class 10 64GB cards
- 1440p
- Micro USB to supply power
- Can be locked/protected against tampering
- LCD screen
- Small profile
