- May 14, 2013
- Carson City, Nevada (USA)
- StreetGuardian.CAM Amazon.com
Send us a support email or private message with your details we'll take care of you.
I have no doubt. Your customer support is unmatched and an example for other companies.Send us a support email or private message with your details we'll take care of you.
PM’dSend us a support email or private message with your details we'll take care of you.
Replacement GPS on the wayPM’d
Yes the majority of stock should now all be PRO + firmware but Amazon is known for mixing fulfillment stock around awhile before its 100% turned over. It’s better to order direct from us if you don’t think you can handle the special PRO to PRO+ firmware update. (Only needed to connect SGR291CAM rear camera)Does Amazon US have SGGCX2PRO with Pro + firmware installed yet? Thanks
Amazon will have a mixture of Sandisk A1, Transcend A1 and Samsung.Great! Two additional questions: 1. what brand of micro SD card do you provide? 2. Will parking mode work ok if I plug the power supply into a Koolatron 12V/5amp battery saver cigarette lighter type outlet that cuts off vehicle battery when battery voltage drops to 11V? Two of my four power outlets in my GMC Sierra truck are live full-time.
Like jokiin and sgusa said, this camera needs two circuits for parking mode to work properly. It also has low voltage cut off built in so you won't need that Koolatron battery saver. It would look so much better if you tied into the fuse anyways.Great! Two additional questions: 1. what brand of micro SD card do you provide? 2. Will parking mode work ok if I plug the power supply into a Koolatron 12V/5amp battery saver cigarette lighter type outlet that cuts off vehicle battery when battery voltage drops to 11V? Two of my four power outlets in my GMC Sierra truck are live full-time.
You must be in the northern hemisphere well north of the equatorto not generate too muuch heat if you are parked in the sun ( not that much of a problem this time of the year )
Which Street Guardian cameras have the widest angle? | SGGCX2PRO | 5 | |
Dashcam Viewer for Street Guardian SGGCX2PRO customers ($25 USD value) Windows & Mac, Single and Picture in Picture Dual Channel Compatible | SGGCX2PRO | 0 |
