yes, all suggestions are welcomeMe again,
Does the manufacturer accept any suggestions? I've gotten my setup working, but had a couple of ideas.
Thank you.
it's technically possible to have something on the display, it generally doesn't work well for this type of design due to viewing angle, as mentioned in a lot of cases the display can't be seen when installed so probably wouldn't work too well for a lot of people1. Is it possible to have the screen on the front unit be able to display useful data? I especially request the current speed; it seems much safer to not have to look at the instrument panel for this, and analog speedometers aren't the most precise.
2. Can the window attachment brackets have the universal "this end up" symbols printed/molded on them somewhere? I know it is stupid, but I accidentally put my rear window one backwards because I had to lean over/around to attach it.
These are clearly minor matters and I am impressed by the product. Also, whoever picked the defaults did a very surprizing job. Time zone, frequency and other objective things were all set correctly already. I don't think even Microsoft and Apple are that with it.
SG are selling 2 nifty little INFO displays, one GPS only the other OBD with additional info from there. https://streetguardian.info/digital-speed-displays
OBD one will of course have the same speed inaccuracy as your car speedo, not sure you can tweak it to display a more accurate speed, personally i would go for the GPS version.
Okay cool in that case i would go for the OBD model for the increased geek-ness alone.
For the display on the screen of speed, I was thinking of an option rather that could be enabled if useful.
My own most nerdy wish are still the ability to have the camera warn if one of XXX plates entered into the camera are behind / in front of me, just to aid my inherent ability to spot undercover cop cars i have had since i was young and a parasite on Danish society.
I don't really have a need for a feature like that, but it would satisfy my inner geek if it was there.
