Hi all together,
I've been reading in this incredible valuable forum for a while now, I even got my autoexec.ash up and running quite good with all the information found here. But now I'm totally stuck. Hopefully you can still assist here...
My plan is to automatically start jpg captures for a long timelapse when the camera is turned on, these pictures are pulled from the cam's FTP automatically (which is all working fine so far, just have to figure out how to clean up the SD card from the already downloaded jpg's and schedule capturing during daytime only, but the important topic first...)
my autoexec.ash contains these simple lines:
which is working fine, but just for about 4 to 5 pictures, then the cam simply stops capturing pictures. The script is still running (which is noticeable when you add beeps to it).
also tried to outsource the loop in another .ash (or .sh) file which is called from the autoexec.ash - same behaviour.
Changing the sleep time also makes no difference.
Adding a "t app key shutter" with and without sleep inbetween also leads to the same exhausting result -> a hand full of pictures taken, nothing more.
Besides some inspiration how to proceed I'd be happy to know if there is some kind of logging which can be checked? All this try and error makes me go nuts ...
every input is appreciated
while true
do
t app key shutter
sleep 16
done which is working fine, but just for about 4 to 5 pictures, then the cam simply stops capturing pictures. The script is still running (which is noticeable when you add beeps to it).
