Testing and review of the VanTrue N2X dashcam
Mark S-H
Pomorie, Bulgaria
Bulgaria
K6000, G1WH, G1WC, B1W, B4K, VanTrue N2X
Testing and review of the Vantrue N2X dashcam​
I received a PM from Vantrue asking me if I would be willing to conduct a test and review of their N2X dashcams. I told them I would be very pleased to conduct a review.
The Vantrue N2X website:
https://www.vantrue.net/product/n2x
The Vantrue N2X User manual:
https://vantrue-app.vantruecam.com/files/manuals/N2X.pdf
The Vantrue N2X firmware updates can be found here:
https://www.vantrue.net/Support/flleDlist/p_id/279.html
(please refer to page 25 of the user manual for firmware updates)
The Vantrue N2X video player:
https://www.vantrue.net/app/app.html
It is possible to buy the Vantrue N2X camera from the Amazon store here:
https://www.amazon.com/dp/B0D9GRRXH5?th=1
I received the Vantrue N2X dashcam about 2 weeks later delivered by courier with a tracking number. In the outer packaging was the box containing the N2X camera together with user manual, 2x windscreen stickers, 2x antistatic stickers, 1x lens cleaning cloth, a leaflet showing QR codes to download the Vantrue app to your mobile telephone and also a QR code to register the camera and activate an 18-month extended warranty and a leaflet offering the buyer to share a video on YouTube potentially to win either a 64Gb SD card or a hardwire kit.
The camera comes with a full 12 months warranty and if you register the camera (www.vantrue.net/register) you can extend the warranty for 18 months.
Please note: The Vantrue micro-SD (high endurance) cards and the hardwire kits do not come with the N2X camera but they can be purchased separately.
Vantrue can supply SD memory cards but if you source the card from another supplier then they recommend that you use a high endurance SD card up to a maximum of 512Gb, with a minimum write speed of 30MB/s and the specifications within the red box.
To insert the card the metal contacts must be facing the front of the camera.
Also in the camera box was another box containing a power adapter with a 11.5’ (3.5m) cable, magnetic mount, USB cable for data transfer (with 1m cable), plastic crowbar (for tucking wires behind facia panels), 3x cable mounts and 2x 3M windscreen mounting brackets.
Some of the Vantrue N2X camera specifications are:
  • A variety of 10 different languages
  • WiFi connection to a mobile telephone
  • SD card storage 512Gb Maximum
  • Video format MP4/Picture format JPG
  • C Type USB connections
  • A front facing camera with various resolutions
  • A cabin camera with various resolutions and Infra-Red lights
  • A 2 Inch IPS screen
  • On-screen speed display (MPH/KMH)
  • Audio recording with noise reduction
  • GPS Sensor
  • Smart voice control operations with a set of inbuilt commands
  • G sensor with video auto-lock
  • Parking mode monitoring and collision detection
  • Loop recording
  • Time lapse recording
  • Facility to rotate the display 180
  • Facility to mirror the cabin view display.
  • Number plate markings
  • Format card reminder for Off/15 Days/ 1 Month
  • Milage statistics
  • SW/WT (Summertime/Wintertime) switch
You may notice when holding the Vantrue N2X camera tends to feel quite heavy. I decided to weigh it and discovered it weighs 176 grammes (6.2 ounces) without the magnetic mount.
You will notice on the front of the camera the main camera lens, and the position for mounting onto the windscreen magnetic mount.
On the end of the camera, you will find the C Type connector used for transferring the videos and photos to a computer, the SD card slot, the speaker and the reset button.
On the bottom of the camera, you will find 4 buttons and the microphone.
The buttons have various functions depending on whether the camera is recording or in the menu mode. Please refer to the instruction sheet or the user manual for details.
Remove the N2X camera button instruction sticker (this refers to the 1 button on the rear and 4 buttons located at end and at the bottom of the camera), from the camera screen. This sticker comes with quite strong adhesive but with gentle persuasion it can be removed. Keep this sticker for reference and also remove the small lens protectors from each camera lens.
Next attach one of the 3M screen mounting stickers to the magnetic mount and then mount it to the camera. I noticed that the magnetic mount can be adjusted through an angle of about 22° to about 50° (maybe suitable for an SUV or truck). I am thinking that a truck with a near vertical windscreen the N2X camera may not be suitable for this type of vehicle. Fortunately, the windscreen on my Jeep has an angle of about 50° so the camera aligns just fine with the road. I am thinking it would be a problem if the windscreen was greater than 50° unless some sort of angled wedge was used between the windscreen and the magnetic mount.
Referring to the diagram on page 4 in the user manual, the camera is placed on the windscreen with the use of an antistatic sticker. Thoroughly clean the area of the windscreen where you plan to mount the camera. Peel off the protective backing of the antistatic sticker and stick the antistatic sticker on the windscreen in the desired location making sure that when the camera is stuck to the antistatic sticker the front lens is able to see the road without any obstructions. Now peel off the other protective backing of the antistatic sticker and then stick the camera to the antistatic sticker. Place the SD card in the camera and connect up the power supply from the power accessory outlet of the vehicle to the ‘C’ connector socket on the camera magnetic mount.
Start the vehicle engine and the camera will boot up.
At first you will need to go through the startup sequence of setting the camera to your preferences. By using the up and down buttons and the OK buttons this will be the Language, the Time zone (+/- GMT), Date format MM/DD/YY or YY/MM/DD or DD/MM/YY, then set the date and time manually use the up/down buttons and OK buttons, then select the frequency to your country 50Hz or 60Hz, then the speed in either KM/H or MPH, then the WiFi Mode either 2.4G or 5G, then format reminder of either 15 days, 1 Month or Off, then format the card (select the tick and press OK) then card will format and the camera will start recording.
The video resolution defaults to 1440P+1080P 30FPS and WiFi, GPS signal, G sensor, 1 minute recording, microphone on, and SD card symbol.
At the bottom of the screen, you will normally see the recording time, date, time and the voice commands activation symbol.
The orange bar at the bottom of the screen refers to the buttons on the bottom of the camera.
The menu cannot be accessed while the camera is recording. To access the menu, quickly press the leftmost button on the bottom which will pause the recording then press the rightmost menu button. The menu contains 3 options, recording setup, system setup, view files
There are 12 installed voice commands which are:
Take Photo
Video Start
Turn On Audio
Turn Off Audio
Turn On Screen
Turn Off Screen
Turn On Wi-Fi
Turn Off Wi-Fi
Lock The Video
Show Front Camera
Inside Video On
Show Both Cameras
Currently the supported languages for voice command are English, Japanese, Chinese and Russian.
The N2X camera is extremely easy to be mounted and unmounted from the magnetic windscreen mount without disconnecting the power supply.
The magnetic windscreen mount can also be detached from the 3M mount.
Connecting to the N2X camera to using a mobile telephone is very easy.
Scan and download either Apple or Android VanTrue mobile app from the Q-Code in the picture below.
Open up the WiFi network within settings on your mobile telephone and connect to the N2X_Vantrue network and then on the mobile app select Add Device, then Nexus Series, then the N2X_Vantrue camera. The initial password is ‘12345678’ which can be changed using the mobile app only. Please read section 2.3.1 in the user manual for more detailed information.
All of the N2X camera commands and more can be found in the mobile app.
The image quality of both the front and cabin cameras are in my opinion superb. The images are very clear and the colour is near perfect. It is difficult to fault the videos and images. Signs and number plates are very clear.
Below are some screenshots from both front and cabin camera and also a link to a 4K video on YouTube showing 6 minutes of the excellent quality of the N2X video.
https://youtu.be/Kyqzy-3gY7s
If you have the HUD option set within the menu then after startup and set time the display will change to the HUD display and you will see similar as below. This shows the speed, a compass heading and the current time.
If you download the video files from the camera onto a computer and within the Vantrue video player you have the ability of displaying the video, map, speed, Latitude/Longitude and several other useful controls. Also, the terrain map can be toggled and changed to a satellite view map by clicking the icon in the very top right of the map. A number of other useful options can be selected within the video player.
Please also watch a demonstration of the video player here:
https://youtu.be/R5-lLtZm9gE
Attachments​
I am at the moment using the cigar lighter power adapter but it’s possible to purchase a hardwire kit from Vantrue from the link below:
https://www.vantrue.com/collections/hardwire-kit
The hardwire kit that I have received comes with a user installation manual and as shown in the photos below.
Also included are 2 packets of fuse connectors (4 fuse connectors in each packet).
E&OE. Thank you.
