TF2EZ v Marcu 1
robertthegreat
England
Would the TF2EZ be a better camera than the Marcus 1 the up side of the Marcu 1 you have gps. But the Tf2ez has WDR and noise reduction. For better night recording. Which would you go for.
CheckYourLights
Front&Rear-SH800/ Front 2nd Vico-Opia 2
Unless you need GPS or size is an issue I believe the TF2 EZ is the better device. It's my understanding that the only thing the Marcus 1 is better then is the SF2 which both use the A2.
I know the A2 is super mature and stable, but the A5 is really solid in the TF2.
CheckYourLights
Tf2 but only with 5.0 firmware
I forgot this as well. If you use a higher version firmware the ability to manually set Wide Dynamic Range will be taken away and become auto applied by the camera making low light condition recorded video worse than before.
The TF2 Plus Premium also has this problem if updated to the most recent firmware.
cheery3853
I prefer tf2ez 5.0, not 5.2 cs firmware. Marcus 1 just need a firmware to fix the exposure, contrast and noise reduction at night.
