Hobbymat
- Jul 29, 2014
- Finland
I purchased an A118 camera a few weeks ago from FoxOffer. The camera came quickly and I decided to install it on my rear window due to its wide viewing angle. However, I've noticed that the camera image quality goes from "rather good" to "extremely bad" during a 20-minute trip.
It seems as if the image focus shifts slowly from "infinite" to "very close" if the camera is recording for more than a few minutes. Then again, after the camera has been sitting still long enough without power, the sharp image I've expected from this camera is there again, at least for a while.
I've attached two snapshots of the A118 recordings. The first one is taken after a 20-minute drive to work, the second one is taken just before I leave home in the evening, at the same spot. The camera has "cooled down" about seven hours between the shots.
The first image (camera hot) is totally out of focus, except for one rear window defroster wire that you can see in the lower left corner of the image. That wire is located a couple of inches from the camera. The second image (camera cooled down) is almost usable at least in the center area, but in this image that previously mentioned defroster wire close to the camera is now unsharp - as it of course should be at that distance. Clearly the focus of the camera optics has changed radically when the camera has been standing without power for a few hours.
Has anybody else seen this to happen in their A118 cameras, or have I only received a lemon from FoxOffer?
