Transcend 16Gb Class 6 or Class 10.I would like to to ask which microSD card do you recommend for GT550WS?
I'm using a SanDisk 32gb, class 10. Directions specify at least a class 6 and when I tried a class 4 that I had lying around it didn't like it. But this one works perfectly.
https://www.amazon.com/gp/B009QZH7D8
64gb will work but its not officially documented by the manufacturerI have successfully used a 64GB ADATA Premier UHS-1 (part number: AUSDX64GUICL10).
Curious if you needed to do any special format proceduresI have successfully used a 64GB ADATA Premier UHS-1 (part number: AUSDX64GUICL10).
When I had the GT550WS, I put in a Sandisk 64GB that was taken straight out of the package and it worked fine. It was formatted with exFAT.
KuoH
works and compatible are two different things, if you can't format it in the camera and then use it then I wouldn't class it as compatible
