The forum is randomly very slow to respond (16.07.2016)
Module 79L
Module 79L
Portugal
AT11DA, SG9665XS, G1W-H
But we don't know if the "problem" was manifesting itself while the test was being carried out. It never happened again since I did the test.
Just to be clear, it's not that the forum is slow, it's just that it randomly takes a long time to respond and ends up not executing the requested command. Clicking again does it immediately.
Module 79L
Module 79L
Portugal
does your ISP run a transparent proxy?
I don't know what that is, so I can't give you an answer. But if this was an ISP problem, shouldn't it affect all the websites I visit?
Did a tracert the last two times it happened. The 2nd time was done as I was waiting for the post in the background to be saved. I clicked "Save changes", the "waiting" gray rectangle appeared on the top right corner of the page for 30 odd secs, then disappeared and the page remained as you can see in the screen grab.
jokiin
Too many ¯\_(ツ)_/¯
no, plenty of websites run fine like this, the service providers do it to save bandwidth
what sort of internet service do you have?
Module 79L
Module 79L
Portugal
Vodafone fiber both at work and home (not the same line). At work I receive it via WiFi and at home via LAN cable.
Module 79L
Module 79L
Portugal
do you get the same issue at work and home?
Yes. At work I have 2 computers, one with Win 7 32bits and the other with Win 8.1 64bits, and at home I have one with Win 7 64bits. I use Firefox in all of them and they all do the same thing. I'm sending this post from the 8.1 computer.
Edit: again, had to click twice to send the post because the first time nothing happened. :confused:
jokiin
Too many ¯\_(ツ)_/¯
can you try it from a different connection altogether, work and home are still the same ISP so if they're proxying you'll likely see the same issue if it's related to your internet provider
Module 79L
Module 79L
Portugal
Didn't happen again since Monday. Whatever it was, it's apparently solved. I hope. **knock on wood**
