AndrewL
- Aug 10, 2015
- Canada
Found a dash cam company "AX-Zone" who had two great posts that some technically minded people might enjoy. Perhaps one of the manufacturers could verify if it's true.
Ambarella A7LA50 vs Ambarella A7LZ50D
Post link
The basic difference between these two chipsets are: with D, means has an internal DDR. This DDR is 1G byte. It is enough for the basic functions. But it is not enough for some functions, like speed cam, and other functions. We made a following picture to help you understand the difference. And why we use the A7L50, not the A7L50D.
AR0330 vs OV4689 on Ambarella A7
Post link
Ambarella A7 solution in the market now uses different sensor, and each sensor produces different functions.
Here the AR0330 means only this sensor, not the upgrade one which supports 1080P60fps. Spec is here
From this sheet, you can see:
1. Only OV4689 supports HDR function.
2. OV4689 support 1080P60fps, while AR0330 cannot (basic AR0330)
3. Both sensors can support SuperHD, if using the A7LA50 chipset.
Yellow cells mean the feature is supported
Post link
Post link
