Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
Surely the whole point of cables with the camera on the end is that they can be extended easily?
I assume that a camera cable will require four cores (+/- power and two for the video, perhaps two more if you have audio), if you are going to make extension leads that can be plugged in to make it longer then please make sure the plugs are round instead of square. This way way you can use heat-shrink wrap rubber to seal it, square plugs can rarely be sealed fully.
On the subject of wiring, if it's going on a bike it probably needs to be a bit more robust than you would need in a car. Perhaps taking a leaf out of the CCTV market and using a Cat5 style cable for the wiring would work well, it won't be as flexible as the normal thin cables but it will survive more abuse. I use Cat5 to run power, video and sound to an external CCTV Dome camera and it works well.
Along these same lines I'm curious to know what method you use to water-seal Cat5 connectors on your CCTV set-up?
