LaLaLandPaddy
Was getting close to pulling the trigger until I read this setup procedure:
Hello Jeff, Also for reference here is our directions for connecting to a vehicle hotspot! May make the process slightly easier.
1) Write Down your phone's SSID and Password for Hotspot. Ensure Hotspot on your smartphone has been turned OFF.
2) Open the Thinkware Cloud App and press the "Not Connected" Bar
3) Select Connect with another Device, then select your Dash Cam model.
4) Select Connect via Hotspot
5) Select Yes, to register the Hotspot.
6) First activate the Dash Cams WiFi and connect to the Thinkware Network.
7) Press Next, and enter your phone's hotspots SSID and Password.
8) Select, Next. The Dash Cam will now disconnect from WiFi and begin looking for a Hotspot.
9) Now Turn on your Phone’s Hotspot and DO NOT LEAVE the Hotspot Setting Screen.
10) Once you hear the Dash Cam say "Connected to the Internet" you can then open the Thinkware Cloud App.
11) Open the Connection Settings option.
12) Select hotspot settings, and select the + Symbol in the top right.
13) Input your cars hotspot's SSID and Password.
14) After the Input has been completed, tap the added Network to connect.
15) The Dash Cam will disconnect from the Phone's Hotspot and begin searching for the Cars Hotspot.
16) Turn off your smartphone's Hotspot.
17) Once you hear "Connected to the Internet" the Dash Cam has been connected to the Cars Hotspot.
Bloody hell!
Brand response from Thinkware Product Expert
Posted 1 year ago.Hello Jeff, Also for reference here is our directions for connecting to a vehicle hotspot! May make the process slightly easier.
Bloody hell!
