Things I learned that I could not find anywhere else:
Skmoejoe
WIsconsin
I recently installed a B1M camera on my bike and I had a few annoying issues that I was able to work through. I wasn't really able to find answers or directions to help me figure it out. Here's a few things I found that might be worth something to someone going through the install process.
  • Unit powers up, does not beep and the Wi-Fi doesn’t work: LED 1 only light on
    • Most likely cause was the SD card was not formatted properly in FAT32. I was using a 128g card. To format a card of this size, there’s a specific way to do it and plenty of “How to” tutorials out there.
    • Formatted to FAT32 and Wi-Fi finally worked
  • Unit powers up, Wi-Fi LED1 illuminates, unit beeps continuously
    • Reformatted SD card in FAT32 again, (still beeped)
    • Found a camera cable pulled loose when I put parts back on the bike
  • Connect to Wi-Fi with phone and no picture, unit beeping
    • Found loose cable connector on camera.
    • When connecting the camera cables, I was cautious about using too much force. When the connections were finally tight, the connectors “snapped” into place.
  • My tips for successful install
    • Use the USB supplied cable with a 110-power cube to energize the unit before installation and test all the functions
    • Make sure the SD card is formatted in FAT32
    • Make sure the cable connections are secure
  • Other comments
    • No problems connecting to the DVR unit once the Wi-Fi was up, phone in airplane mode
    • There is a lot of cable—almost too much. I wish there were a way to shorten it.
    • I wired my ACC (yellow wire) into a taillight using a multimeter to find the wire with power when the ignition was on; red went to battery.
    • Initial video looks pretty good but not up to GoPro standards.
Leonauto
Smolensk
Russian Federation
B1W, B2W, Viofo A119 PRO, A119 V3, MT1, B1M
The main thing for the user: when the B1M beeps, it means that video is not being recorded (i.e., for various reasons - when there is no memory card, or it is not formatted, or the camera is not connected)
estore009
Retailer
Shenzhen
China
B1W/B2W/B2K/B4K/DV688/DV988/B1M/B2M
This unit does not reboot after powering on if without plugging the front camera or the front camera connector loosen!
The unit keeps beeping continuously after powering on and its No. 5 Led light blinks, it indicates that the rear camera connector loosen!
Which cable do you want to shorten?
Suggest tapping the red wire and yellow wire to the same ACC switch. It can avoid the battery drain problem if without usage for a long long time!
The newer firmware 20200901 should be much better video quality. You can give it a try!
Padre
I would love to know how to shorten the cables, especially the camera and GPS cables. There is SOOOOOO much cable!!!! Hard to hide it and find a place to put it under the seat of my Harley Street Glide. Really, so much cable, is it really necessary for a motorcycle??
estore009
Retailer
Shenzhen
China
Do you refer to this 2 meters extension cable for the camera?
Padre
No. The regular camera cables and the GPS cables are long enough to go around my bike 3 times. Grossly too long.
