Uluz60
Tennessee
New here folks. I recently purchased and installed the Thinkware U1000 Front and rear camera system. I have been having an issue since installation that the camera will not turn off and go into parking mode once the ignition is off. I troubleshot the entire system, called thinkeware and they instructed me to contact Cellink about their wiring harness I purchased with the battery (premiered system). I did so and was sent out a replacement as that may have been the issue however, it is still doing the same thing of not powering off and entering parking mode. Has anyone encountered this issue and if so, how did they rectify it?
Spoonie
Silver Spring, MD
Q800PRO
Is it possible that the wire that connected to your Celllink Neo is not a B+, but an always-on connection? That will cause your camera to not go into parking mode. Once the celllink sees the voltage drop, it then goes into parking mode. What type of vehicle is this installed on?
egonvdv
A Dutchy in the South of France
France
TWO Thinkware's U10002CH (rear cams used as side cams)
the newwer thinkware cables went from red being permanent power to yellow, (and vice versa for AAC)
so maybe thinkware red should be on cellink yellow (this is the case in my setup)
U
Uluz60
Tennessee
THE VEHICLE IS A 2005 NISSAN TITAN. I PURCHASED THE PRE-WIRED WIRE HARNESS FROM CELLINK. I THOUGHT THAT THIS WAS THE ISSUE AND CALLED AND WAS SENT OUT ANOTHER SET HOWEVER, IT IS DOING THE SAME THING
Spoonie
Silver Spring, MD
Q800PRO
Can you take a photo of your fuse box label, and tell me which fuse you're tapped into? I've got a Nissan Altima, and sometimes Nissan's can be a little tricky. My friend has a Rogue that I installed a cam in, and it was hell trying to find a fuse that wasn't Battery +
U
Uluz60
Tennessee
I think I am going to call Cellink again and ask for cable in which I can wire myself as opposed to the pre-wired set.
Spoonie
Silver Spring, MD
Q800PRO
You should only have two plugs on the celllink connector. One for ground, and another for acc+ that you use a fuse tap for. the other end plugs into the battery. I'm sure it's something easy that's being overlooked.
U
Uluz60
Tennessee
Spoonie
Silver Spring, MD
Q800PRO
I'm assuming you've circled the fuse you're tapped into the 15amp accessory fuse? I would've picked that one, or the one above it. Also, your vehicle may have retained accessory power for up to 10 mins after you've cut the vehicle off (unless you open a door). Are you aware of this feature on your Titan? This isn't something that can be turned off, but it will be fine once you turn off the vehicle and THEN open a door. Give it a shot, and let me know. Sounds like you've hooked it up correctly. Also sounds like you have a good ground.
Can you use the celllink neo app to see it charging and going into park mode once the battery is off?
Is parking mode turned on in the camera settings (found this our the hard way after taking hours for a 45 minute install)
U
Uluz60
Tennessee
Yes, that is the fuse I am currently tapped into. I didn’t think of that feature tho although I am aware of it. With that being said, I did unplug the fuse tap and tested out he socket with my radar detector to see if power was taken away with the engine off as opposed to it constantly being on after. It actually does turn off completely with the power shut off. So I tapped back into the same fuse but it stays on regardless.
I can use the cellink app to monitor and it does charge when truck is on and does turn off(not charge) when turned off.
I did turn on parking mode in the settings unless I am doing it wrong. What does your setup look like in your settings for parking mode?
Spoonie
Silver Spring, MD
Q800PRO
I'm curious if you turned on the cell-link neo? There's a power switch on the back of it. Make sure it's set to the high setting.
U
Uluz60
Tennessee
Thanks for that however, I did have it set to high already and is charging correctly.
EsQueue
Southern California
Do you have a multimeter, a 12 light or anyway of testing pins for power? A few quick tests should easily diagnose the issue.
First I'd test for power to the Neo after power is off. If power gets cut. The output connector of the NEO should have 4 pins I believe. One should be ground, one should be constant 12 and the other should be switched, test to identify which is which. I'd also test the camera by disconnecting either the red or yellow pins and see if that forces it into parking mode.
I have a broken BlackVue 750S and a New 6 with a custom expansion. I will be getting a U1000 in the mail soon so I'll need to figure this out too. I currently have the Blackvue B124 with a cigarette lighter jack. I plan to cut off the cigarette lighter head and pin a new wire for the switched source.
Sky1
Check your power leads,
The Constant on is the YELLOW wire this goes to your CONSTANT power source
the Ignition on is the RED wire, this goes to a 12v signal that is present ONLY when the car is running.
We tend to want to connect red to red, that messed me up first time I connected one.
SawMaster
SC
Numerous and ever-changing
Best to go by the tags on the wires (if there are any) or the instructions with the HWK as different HWK kits will use the red and yellow wires differently.
Sky1
I don't understand, What is the purpose of a cell-link battery when you could simply install a deep cycle Yellow Top Optima in your car as the main unit for 2/3rds the cost?
jokiin
Too many ¯\_(ツ)_/¯
in some vehicles it's not about reserve power, there are vehicles that have issues with power draw when the car is off that will cause the vehicle to disable circuits and will throw error codes, very common on German cars in particular, that's primarily why products like the Cellink came to be in the first place
egonvdv
France
i have 2 cellink pro's piggybacked on the cigarette fuses;
it makes for a clean install and they are placed under the hatch in the trunk/boot.
it would be too difficult to wire a battery from the engine to the trunk, plus the size would be a problem
and as @jokiin n said; it would just keep feeding of my main battery...
Sky1
How long does it take to fully charge the Celllink battery? If you park for a week then take your car to the store up the street and back doesn't seem like that would be long enough to charge them
egonvdv
France
