I have in stock this one:
Comparison:
Can these be used both at the front cam and rear cam to clean things up without connection issues?
Thanks for the info. I just need one for the front cam. Does the one you pictured above actually work with the front cam? If so I'll have one. It does say though in the description that its 25cm and not 50cm.
I have a 2014 Mazda 6, so looks like its not going to work. What would be ideal, would be to have one of these, but 30cm long rather than 25cm long. I have already one of these at 25cm but just isn't quite long enough, 30cm would be ideal. I don't rearly understand why the manufactures don't have them as an option, for situations like this.I can tell you that for me the down direction didn't work with sgzc12rc as the cable was hitting windshield in my Mazda
Not sure why manufacturer did not think about aesthetic look of final installation. L-shape would look much better.I have a 2014 Mazda 6, so looks like its not going to work. What would be ideal, would be to have one of these, but 30cm long rather than 25cm long. I have already one of these at 25cm but just isn't quite long enough, 30cm would be ideal. I don't rearly understand why the manufactures don't have them as an option, for situations like this.
Here is a pic of what I have at the moment.
I'm the customer Niko is referring to. IF he is still getting his L50LEFT and L25LEFT cables from the same supplier (and they are making them in the same way) then ONLY the L50LEFT cable will work because it is 5-wire, whereas the shorter one is only 4-wire. In my tests the front camera needs the 5 wires connected to the Thinkware long cable in order to recognise the rear camera. It seems that it is not necessary to have all 5 connected at the rear camera which suggests that there is simply a sensing circuit in the front camera which is still satisfied if it is open circuit but only if the wire is long enough. I asked Thinkware UK tech support about this but they couldn't help, just telling me that it is designed to use their cable and only their cable.
I would have used the L50LEFT at the front but my camera is mounted behind the rear view mirror so the part of it is visible, moreso than the OP's. I found that the right angle connector was simply too large for my liking. Instead I got parts to make my own cable and the connector is much smaller.
Do you ship to the US?I was trying to search our conversations from e-mails history, but thank you for replaying to this thread, now I can clear up some details and make a notes for future references.
Just to clarify: L50LEFT will work as a front and rear extension and L25LEFT can work only from rear camera extension side, right ?
Usually not, but above mentioned adapters I can dispatch to US at the moment as a temporary exception. Price on the web incl. free shipping.Do you ship to the US?
Correct. Of course there's no guarantee that L25LEFT will still work at the front on every F750 installation since there may be variability between units.I was trying to search our conversations from e-mails history, but thank you for replaying to this thread, now I can clear up some details and make a notes for future references.
You guys think this ll work?
Adaptateur à angle 90 degrés Mini-USB prise et fiche https://www.amazon.fr/gp/B00D8HAX54
B | Bmw F06 640d Thinkware F750 | F750 | 2 | |
G | F750 rear camera compatible with other model Thinkware cameras? | F750 | 3 | |
M | Thinkware F750 + battery packs without hardwiring | F750 | 1 | |
S | Thinkware F750 card orientation | F750 | 2 | |
E | Thinkware F750 How do I install/ update Firmware? | F750 | 2 |
