Thinkware F750 with Rearview camera HELP!
dxb494
I had my Thinkware F750 professionally installed two weeks ago. The quality is awesome.
Yesterday I attached the rearview camera.
The main camera announces that the rearview camera is attached and the system is restarting. The problem is it continues to do that over and over and never actually boots up .
If I unplug the rear view everything is fine!
What might be the problem?
niko
Retailer
Dublin
Ireland
Does system allows to boot up ( get into the menu settings ), or when rear camera is connected and you powering up unit then it boots up and straight away restarts ?
D
dxb494
Hi Niko
It won't allow me to get into the MENU!
It just keeps restarting,
niko
Retailer
Dublin
Ireland
I saw similar thing few years ago on some other Korean 2ch system. If I remember there was two solutions:
1. disconnect rear camera, boot up front camera only, then connect rear camera, go into menu settings and restore to factory default.
2. upload firmware "update" to microsd card, connect both cameras, insert microsd into main unit, boot up unit, FW update will start.
Maybe this may help F750 as well ?
D
dxb494
D
dxb494
Thanks. I'll give #2 a try as I tried #1 but it would just keep restarting.
niko
Retailer
Dublin
Ireland
If #2 will not work for you then I guess you can e-mail to your local distributor.
niko
Retailer
Dublin
Ireland
Fulfilled by amazon ?
D
dxb494
No...A company called Total Tech Outlet.
niko
Retailer
Dublin
Ireland
Hope they can forward your concern to their supplier ( if they are official distributor ? ). Anyway, try #2 and see how it goes.
Dee_82
Thinkware F750
what SD card are you using?
D
dxb494
The 16GB that came with the camera.
Dee_82
Thinkware F750
ok,, try this, power off the camera using the power button, then pull the power cable, remove SD card and download the firmware from here
http://www.thinkware.com/Support/Download
delete everything on the SD card and then copy the CONTENTs of the file you downloaded, you should have a F750-pkg.bin and two folders, settings and driveinfo on the SD card, put the SDcard in and plug in the rear camera, power on the device and let it install the update, see if that works
D
dxb494
Thanks...I'll give that a try once my wife brings the car back :(
niko
Retailer
Dublin
Ireland
Try to format memory card inside unit when only main unit works, then power off device, attach rear camera and power on again.
D
dxb494
Hey ...
I tried the above mentioned suggestions and still the system will restart over and over again. It is a never-ending restarting cycle until I unplug the rear-cam. :(
