Hi everyone,
After some previous hickups, I managed to install the F770 (both front and rear) and get everything working.
Everything working, except for parking mode as I still need to hardwire the dashcam. I have the Thinkware Hardwiring Kit, displayed below:
The manual (well, the small piece of paper included with the kit) tells me I need to connect the black cable to a ground, and then the other cables to a fuse which receives power although the engine is switched off, and another which only receives power when the engine is switched on (as you all probably already know by now).
I'm driving a Volvo V40 - there's a fuse box located on the passenger side, underneath the glove compartment (so not on the left (driver) side).
Let me stress that I am in no way an electronics aficionado, so to say. I already get slightly stressed when I need to wire a lightbulb, and have to doublecheck online or with family members to know for sure I'm doing it right
So, that being said, I did manage to use a multimeter to get a read on the difference fuses located in the box. I discovered that I need to read from one of the two metal points which "peek" through the plastic top cover of the fuse, in order to get a reading. If I'm not mistaken, some of them only give a reading on one of the metal points, which we'll get to later.
I identified the following fuses:
- fuse (61) (10A) entitled (freely translated) as "curtain for glass/panoramic roof"
==> however, my car does not have this (just a regular roof), so I wonder why the fuse is there. In any case, it receives constant power although the engine is switched off, so I could use this one?
- fuse (63) (5A) "collision warning" (constant power)
Finding fuses which do not receive power when the engine is switched off was almost harder than finding ones which do. I identified the following:
- fuse (83) (10A) "central locking fuel cap"
- fuse (84) (10A) "unlocking tailgate"
- fuse (86) (10A) "airbag & pedestrian airbag"
So now, I have the following questions:
1.) Am I doing this right? I have a feeling that the fuses I have identified should be the other way around; it makes more sense to me that a "collision warning" system would only function when the engine is switched on, whereas "unlocking tailgate" would receive power so it can be unlocked even though the engine is not running. Therefore, I'm not 100% sure I'm doing things right. My dashcam is currently connected to the cigarette lighter, and only switches on when the engine is actually running; so not when I switch on the "battery" by pressing the start/stop button without pushing the clutch (e.g. to listen to the radio, for instance). When I was reading the fuses, the doors were open and an interior light was burning: does this mean that the battery was actually switched on, and therefore I got faulty readings (although the engine was not running)? Or is it really about finding fuses which give power only when the engine is running?
2.) Why do I have fuses for parts which are not installed on the car? (e.g. panoramic roof curtain, collision warning); are these fuses then used for something else? Could I use these fuses regardless?
3.) Do I need to look for a specific amount of amps? Some are 5, some are 10...is there a minimum or should I look for a specific one?
4.) And then perhaps the most important question: how do I go about "installing" the wires? I've seen a tutorial where a guy just pulls out the fuses, wraps the metal wire around one of the fuse legs and pushes it back in. I've seen others where people use what is apparently called "add-a-fuse", and looks like some kind of "fuse extension cord" in my eyes. Is there a better way to do things? It seems to me that just wrapping the cord around one of the fuse legs is the more easy-going approach, whereas using an additional "fuse extension" would perhaps be better? Like I said, I have no idea.
5.) In case the first method is used, can I just simply wrap it around one of the fuse legs and plug it back in? Also, which fuse leg should I use? Does this correspond with the one which gives a reading when I touch the metal top part as described above?
I'm a bit anxious with regard to fiddling with electronics, also as this is a company car and I wouldn't like to wake up to a burning wreckage the next day, only to have firemen pull out a 3-meter power cord from the headliner and point out an out-of-the-ordinary kit which was amateuristically connected to the fuse box
So yeah...all help is really appreciated.
Once again, many thanks in advance!
