GPS is notoriously inaccurate for speeds which is why no rule-making body or record certification groups in the world will accept or affirm GPS speed readings. Only certified radar and measured time/distance readings are used where accuracy is paramount. Speed can be accurately extrapolated from the video and if done correctly is always certain and inarguable. For dashcam purposes location can be easily found by video alone. Someone will be investigating the scene so all that matters us that they arrive at the right place- seems that they always do even with no GPS involved. There is more than one numeric protocol (language) for GPS locations and they are not interchangeable, so if they're using another protocol your numbers can't be used by them- your info is then useless. Road names and distances are more universally understood and more generally used. Exact time is rarely relevant, and in a crash or road incident someone will be phoning it in within seconds so the call center will have that time logged. It's plenty close enough.
I can do everything needed without GPS, and with ample or better accuracy too. It's just one more thing which adds to costs and which can fail
GPS has it's uses where it's a godsend but dashcams aren't on that list
Use it if you wish to but know that it' not necessary at all.
