reverend
- Apr 22, 2014
- United Kingdom
- Too many
OK so I recently tried a Xiaomi Yi Smart Camera but that is only really good for monitoring inside the house.
The Transfluent U23 product is unlike anything I've seen before - it's a wifi camera with optional IR (included but you can remove it) that gets it's power from a light socket! I'd been looking for something that could do this so I could fit it into an outside light that I have never used.
That's right - it screws straight in and then you've got a working wifi camera with high quality IR and it also has full motion control so you can rotate it through 360 degrees from an app on your phone (I've only tested iPhone).
It has full RTSP support so you can plug it into software such as Blue Iris, but as I found out today by accident it works out of the box over cellular data with NO ports requiring to be opened on your firewall - I need to work out exactly how that works but it was just totally seamless and with an accidental launch of the U23 app I was sat watching home instantly in high quality.
This product is available from GeekBuying here who kindly supplied this unit:
There is currently a coupon code for $10 available here:
ZCOUWBSC
The version I have here is for a screw type E27 light socket but I actually have B22 sockets here so I used a B22 - E27 adaptor like I use for my Philips Hue bulbs:
https://www.amazon.co.uk/gp/B0076W5FKK
You can actually get these with a standard MR16 bulb type but I don't have any of these here.
It's complicated to describe so here are some pictures of the bits and then the assembled unit at the end:
That's the IR ring on the left which is optional - you don't have to use it and it just snaps over the camera frontage. It's got a light sensor built in and automatically adjusts the intensity of the IR bulbs depending on how dark it is.
The camera itself is towards the bottom with the U23 branding and then you've got the USB power adaptor you can use instead of the light bulb if you so wish and then the common connector to the right which either gets power from USB or from the lightbulb adaptor you can see in the picture below.
You can see a few buttons on the rear of the camera.
You can change the orientation of the camera (ie which way is up), and you can set the Wifi to be in client mode or access point mode. Initially you would start off in access point mode and then when you've configured the camera via your phone with your wifi details you just put it into client mode and reboot it and it joins your local wifi network and literally takes seconds to setup.
That's a rotating ring which has a thumb screw which you use to lock the common power module into the camera itself. It also has a mini USB port you can use to supply power if you don't want to put this into a lightbulb socket.
That shows everything assembled and with the IR ring fitted to the lens you can see at the bottom left and ready for going into a socket.
This shows the iPhone app that you use to configure the camera.
ZCOUWBSC
