needcamsasap
Car: 2019 Subaru STi
So I bought a CellLink Neo battery to pair with my Blackvue 750 2 channel. I got to the point where I hook up the grounding cable to a bolt, and proceeded to buy an add-a-fuse kit 10A and plugged it into the only ACC available (the legend on the Fuse cover had it highlighted yellow and said "ACC" on it) and it's pin was 7.5A. I then also attached this 7.5A pin onto the 10A add-a-fuse kit.
I then turn the car on just to see if the battery charges, and it does charge, but my daytime running lights and AC do not work at all. None of the temperature gauges work either. Where did I go wrong? I undid everything and not to my surprise, my DRL and AC works again.
