Tutorial: How to mount a CPL-filter on the Dome D201
Pianoman144
Germany
Hey Community :),
after i mounted a CPL-filter on my Dome D201, i want to share a quick tutorial how to do this because there are only filters for the D202 or D205. :cool:
1. What i have bought:
- A 37mm to 49mm step up ring (filteradapter) It has to be a one with inner diameter of 37mm!
My is from LUMOS-66 http://www.ebay.de/itm/172344730172?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
- A 49mm Slim CPL-filter.
Just search at ebay or google. I have bought this from ebay http://www.ebay.de/itm/110815754734?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Just make sure you buy a high quality and real glass filter.
2. Prepare the Dome D201
First use a little screwdriver to remove the chrome ring. Just push it up. There are 5 little plastic legs on the ring to hold the chrome ring. They will brake if u push the ring up.
After u removed the chrome ring it looks like this:
Now you are ready to mount the adapter ring on the lens.
3. Mount the CPL-filter on
The adapter ring with inner diameter of 37mm fits perfectly over the lens.
Just push it over and u will see that it will sit solid. If u worry about it, you could use double-sided tap to fix the adapter ring.
Now you can screw on the 49mm CPL-filter.
There you have your CPL-filter mounted on successfully!
Here is a short video showing me how strong the adapter ring fits on the lens without taping it.
Thank you very much for reading this tutorial ;)
Cristian
Romania
DAB-201; A129 Duo
Using a step-up ring 43-49 CPL filter can be installed without removing the chrome ring. So I mounted on my camera.
icecream
Blackview A12 (Dome DAB201)
Even better :)
I'm kinda concern about reflection by chrome ring, how did it go so far?
benjos
Los Angeles
SJ8 Pro, Rexing V1P Max, Dome D201, Xiaomi Yi
What's the correct way to measure the camera for the step up adapter? When I measure the casing, I get 34mm for the inner diameter after I removed the chrome ring, and I get 41mm for the outer diameter. See screenshots. Isn't a 37mm inner diameter going to be loose? I'm using the Rove camera which looks identical to the Dome but it is possible that it's not exactly the same.0511172054_inner.jpg 0511172054_outer.jpg
Cristian
Romania
DAB-201; A129 Duo
On step-up ring 37 mm is diameter of threaded part on outside, inside diameter of ring is smaller
R D201 3
E D201 11
D D201 1
