Good morning to everyone, I have a U1000 with rear camera and radar, wired to the car with the original OBD cable.
I'm writing here because Thinkware is no common in Italy, I hope I will find more answers in this community.
I know that U1000 can work in two separate ways:
- if I want to use the radar feature, dashcam need to be set in Energy Saving mode. So, it's impossibile to use Live view.
- if I want to use the Live view, Energy saving must be disabled.
Said that, in my car I've a 4G mobile hotspot with a data plan, powered by a backup battery: network is always available.
What is the problem? I don't understand how dashcam works.
In energy saving mode, when the U1000 is connected through WiFi to my smartphone, if I turn off the car, close it and go away, the U1000 disconnect from the smartphone and WiFi led start blinking in blue until it finds the hotspot...after some seconds, it connects to the hotspot and stay connected for....I don't understand. Also 1 hour, sometimes 10 minutes. In this time, if I try to connect from my smartphone, I can use the live view feature, which stop to works when it goes in real parking mode.
Also, if i disabled energy saving, the behaviour of the dashcam is the same. Sometimes it stops to works in this mode after 1 minute, sometimes after 1 hour.
At first, I suppose that could be a problem related to the battery voltage, so I set 12V in the app as limit, but i tried also with a battery charged connected to the car, to have constantly 13v, and there's no change.
I simply would know what are the steps that I have to do in order to choose two different scenarios, because sometimes i need the radar feature and other times the Live view feature.
Thanks in advance!
Thanks in advance!
