Hi!
I am new to dash cam and found this forum. I was reading an article from BlackboxMyCar and it says :
I was under the impression that if the memory card is faster than the dash cam, the memory card will not make or force the dash cam to process faster than it was designed.
The speed of U3 card is not fixed and will it will just run on the speed that dash cam supports.
I see the point of the article to get ideal card and not waste money for a faster card that will not add any benefits. My concern is the " may heat up excessively" part.
Can anyone can shed some light or experience with this?
Thank you!
Got a Thinkware U1000 Dual Channel dash cam? Because the U1000 offers 4K in the front camera and 2K in the rear camera, you can opt for a UHS Class 3 SD card, like the Samsung Evo Plus.
But be sure not to use a UHS-I U3 card in a Full HD dash cam - the main board may not be designed to process faster than Class 10 or UHS-1 card and the dash cam may heat up excessively.
Thank you!
