Unable to connect to Wifi
Buffi
Switzerland
Hi,
I just bought the B1W and inserted a FAT32-formatted 16GB class 10 micro SD card. I try to connect via my Xiaomi A2 Lite and it finds the SSID B1W_c46e7b0fe82b. Use the default 1234567890 password. When i try to connect with the app it says something like "Error getting device information".
Mobile-Data is turned off.
B1W is connected with the 12V-plug.
When i check the wifi-settings, i see that after connecting to the B1W-Wifi the Wifi changes immediatly (~1s) to "deactivated" without any message. Than i tried to connect to the Wifi with a wrong password to check if there is any error message, but its the same behaviour.
I also tried to deactivate the wifi on B1w by pushing the button (~5s), but it seems the button has no function.. Wifi is still available.
Do you have any hints?
Do you update your phone recently? Android 9.0 on your Xiaomi A2 lite?
If yes, you should remove the previous APP and install again!
Yes, the phone has Android 9.0.
I installed the App yesterday - Version 1.8.5.
No Android update received/installed since yesterday.
Gave a test with my Huawei Mate 20 Pro, it works!
And could you mind to give me the APP crash log files for checking? You can find the crash log in your phone "file management" section!
Hi,
The Folder B1W DashCam has no files inside (only empty folders)
Here is the file inside WifiCameraCrashLog directory (log renamed to txt).
  • crash-2019-03-06-08-35-23-1551857723365.txt
@Buffi PM you the firmware to reset camera already, and give it a try and back to me!
Thank you, now the cam is working.
