Leaky Waders
I installed my 1st dash cam in a 2020 Honda Ridgeline. I have hardwired it to the fuse boxes. I selected one fuse slot from each fuse box. When I turn on the vehicle the unit does not power up. If I manually press and hold the power button the unit boots and starts recording. I have to manually turn the unit off when I turn off the truck or it continues to record. The same is true if the truck is off, if I press and hold the power button the unit boots and records. I also noticed when I connected the ground wire to a bolt I saw one small spark. I must be doing something wrong but after watching a dozen videos I am not quite sure what. I used a multi-meter to confirm that the fuses I selected were either always on or on with ignition power. TIA for your help.
