R
Richard Ayrton
Guest
Hello, would anyone know the length of the unit once the cable tidy is connected?
Many thanks.
Many thanks.
Thank you @Nico I have a large panoramic windscreen with no trim to hide the cable. So looking to maximise the wedge design and cable run.Cable tidy is 9.5cm long, B40 is about 7 cm, total length is around 16.5cm
Correct; looking to extend any cable tidy. Also looking at the possibility of using something like a Mobius mounted on the dash as opposed to the window. Thanks for your help.No problem.
As I understood you are looking to find something to extend cable tidy ?
Maybe black colour cables covers will do the job ? But it may be hard to find correct size ( width / height ), just giving you some ideas.
You are welcome.Correct; looking to extend any cable tidy. Also looking at the possibility of using something like a Mobius mounted on the dash as opposed to the window. Thanks for your help.
Citroen C4 Picasso, '10 plate. The model I have does not have the rain sensor and trim which would help hide any cables. Just loads of glassYou are welcome.
May I ask what car make / model / year do you have ?
probably the largest windscreen on any passenger car, those things are huge
Sadly not. No trim between the headlining and the mirror. There is a gap of 22cm between the rear view mirror and the sun visor tracks. That's why something on the dash / A pillar will probably be more appropriate.
Thank you for the photos....Is the Mobius mounted on the dash have enough elevation to get a decent view of the road ahead?Sometimes my dash-top has the Cobra 840 but at other times it has a JooVuu X or Mobius C2.
Today it's set up for a curious experiment into defeating 'flash for cash' type scams after a comment made by @Kip here: > link <
Often I have a cam peeping through the driver's small A-pillar window recording 720p60 but not all cars have A-pillar windows.
Pics of experimental setup for my journey today (2x Mobius C2c at right angle to each other).
The adhesive mounts have a small screw inside the cup which penetrates about a quarter inch into the dash top because I find adhesive alone doesn't stick.
I have 2 Mobius cams, & they're a good choice. For your car, I'd probably go with something like the SGZC12RC for it's form factor & discreet / minuscule nature. Both shown below ...Cheers guys for the suggestions. Other than for the rear of the car, I don't think the wedge shape is the most suitable. However, still the form factor I prefer!
I'll bob over to the Mobius / Joovuu threads for a mooch
GPS unit (generic) Dead | A118 (B40) | 0 | ||
Distorted video signal output to headunit | A118 (B40) | 35 | ||
On my 3rd unit, camera is stuck in Mass Storage mode | A118 (B40) | 10 |
